Japanese Tires... 205/45/17 - 215/45/17
Old 04-12-2008, 10:49 PM
Sin MINI's Avatar
Sin MINI
Sin MINI is offline
Originally Posted by paipuky
A wider tire gives you more rubber in the ground = more traction... but my point is having a smaller tire in radius. That will make the wheels spin more times = more gas.
The amount of rubber on the ground (aka "footprint") is determined by the weight on the wheel and the tire pressure. A wider tire at the same pressure and no change in overall car weight means the same amount of rubber in contact with the ground.
  #77
Old 04-13-2008, 12:40 AM
ninjlao's Avatar
ninjlao
ninjlao is offline
Ninja Mini
Yokohama Advans
  #78
Old 07-29-2009, 01:27 PM
bubbabrown200's Avatar
bubbabrown200
bubbabrown200 is offline
Hankook Ventus Sport K104
Just a warning about these, I have less then 8k miles on them and there already shredded and done. Worst tires I have ever had.
  #79
Old 07-29-2009, 01:59 PM
Speedee's Avatar
Speedee
Speedee is offline
Been reading this thread for some time now... Have yet to hear a bad report or experience with the Yokahama S Drives... Quiet ride, great handling, grippy, good in the wet, long life.... I'm about to ditch my run flats for a set of 215/45/17's, also hoping this will correct the built in speedo error.
  #80
Old 07-29-2009, 10:11 PM
minihune's Avatar
minihune
minihune is offline
OVERDRIVE - Racing Champion
S.Drive tires have been criticized by EVO magazine late last year for not being as good handling especially in the wet.
Tirerack tests show-
http://www.tirerack.com/tires/tests/...t.jsp?ttid=104
http://www.tirerack.com/tires/tests/...y.jsp?ttid=104
Yokohama S.drive (Ultra High Performance Summer 225/45R17)
Quote-
What We Liked: Quick steering response and sporty feel
What We'd Improve: Increase wet traction and a small improvement in ride comfort
Conclusion: A sporty tire tuned for enthusiasts who want to feel connected to the road
Latest Test Rank: 3rd
Previous Test Rank: 3rd (August '07)
Higher rated tires-
Michelin Pilot Exalto PE2
Bridgestone Potenza RE760 Sport
see
http://www.tirerack.com/tires/survey...y.jsp?type=UHP
  #81
Old 07-31-2009, 06:58 AM
txwerks's Avatar
txwerks
txwerks is offline
We have S.Drives on our e46 330ci 'vert cruiser car, and I have to say that I am less than impressed. The inline-6 can roast them in the dry, and they're downright crap when it's wet.
I just ordered a set of Neo Gens for street tires for our test mule Cooper. I had been running Hankook V4-ES, which aren't bad (and were cheap at the time). I found the Neo Gens for a criminal price at onlinetires.com and we've been running NT-01's for awhile and loving them on the track, so I figured I'd give the Neo Gens a shot. The other tire that caught my eye was the new Hankook v12 evo, which is a max performance tire.
Other tires we've had over the years for street, on our R53 and R50 track mules:
Yokohama ES100's - meh, good thing they were cheap at the time
Falken RT-215 - tons of fun - until it rained
Falken RT-615 - even better in the dry, better in the wet but still bad
Falken FK-451 - mediocre at best
Toyo T1R - mediocre
BFG G-Force Sport - surprisingly good in the dry, decent in the wet
Hankook RS-2 - great dry, decent wet until worn down
Overall, the better street tires so far have been the V4-ES and the BFG's. Both were predictable in the dry (these aren't max or extreme performance tires, after all), with the V4-ES having a slight advantage in the wet.
While most would think we'd be after a summer tire here in Dallas, we've just found that they get eaten up too quickly with all the negative camber we run up front (yes, even with frequent rotation). We do get some major rains at times, so that is a consideration. Mainly, we just look for something that's quiet, lasts longer than a year, and is good in the dry and decent in the wet stuff. We're not looking to drive like maniacs on the street, either, because that belongs at the track...
vbmike
10-15-2015 04:32 AM
srhodes
10-08-2015 05:17 PM
Mazarin
09-15-2015 08:45 AM
Alex@tirerack
Tires, Wheels, & Brakes
12-04-2002 05:03 PM
Quick Reply: Japanese Tires... 205/45/17 - 215/45/17
