Will it be ok to put 215/50/15's on the front and 205/50/15's on the rear?
It is time for some new tires! I want to go with the BfGoodrich G-force sports again. I am considering putting 215/50/15's on the front and 205/50/15's on the rear. I heard by putting wider tires on the front, the car will oversteer more. This true? Also I have a 15x6.5 rim, will the 215's be ok on them? Will having a wider tire on the front effect the ride any? (make it twichy?)
Some RWD vehicles have wider rear tires than the fronts to help control oversteer and put the power down better (Corvettes, for example). I don't see why you couldn't try it on a Mini by putting the wider set on the front. The disadvantage would be that you can no longer do a typical tire rotation to help extend their life.
The Tire rotation isnt as bad as it looks. The one thing I forgot to mention was tire compounds. Had Toyo Ra-1 in front and Hankook Rs-2 in back. For me if the car had same size and compounds. The car would push a bit much on low speed corners due to the Phantom Grip in the Diff.
Again I like the loosness which the compounds are a major factor.
07-16-2020 12:54 PM
Interior/Exterior Need Help With Exterior Decisions (05' MCS PHM/W)
boostedhaze
01-02-2018 07:26 PM
ClayTaylorNC
08-10-2015 09:19 PM
