WHY DO PEOPLE BUY 205-40-17s
OK. I've heard all that's bad about this tire size. Low load rating, pot hole problems, rough ride, etc. But, there must be a plus besides lower weight--or is there? Is it just for show. I bought a set of used wheels that have Yokohamas S drives on them in this size. By the way, the load rating is 84, even on the 205-40-17s. Is there any improvements, like handling, etc. that I can look forward to, or is it all for show? I would really like to know. Thanks.
They are cheaper than 205/45R17 and lighter. I would consider those two conditions a plus.
Leo Barrios
leo@edgeracing.com
800-489-5353 x211
http://www.edgeracing.com
Leo Barrios
leo@edgeracing.com
800-489-5353 x211
For the MINI, 205/45-17 gives the best blend of tire size, load rating, good handling and comfort within design constraints.
Other cars that need a small wheel and tire with less weight or even 2 seaters could get by with 205/40-17.
205/40-17 is a popular size. It used to have even lower load ratings but some tires today are at the limit for the MINI, about 84 load rated.
Looking at the Goodyear Eagle F1 GSD3 as an example
205/40-17 $125 each,fits 7-8" wide rims, perfect:7.5" rim 84 load, 23.4" tire diam.22 lbs
215/40-17 $153 each, fits 7-8.5" wide rims, perfect:7.5" rim 83 load, 23.8" tire diam.19 lbs
215/45-17 $135 each, fits 7-8" wide rims, perfect:7" rim 91 load, 24.6" tire diam.24 lbs. Note-load rating higher due to XL tire.
So if you want lower profile side walls and lower weight with moderate cost then one option is 205/40-17 or even 215/40-17 (more costly).
45 series tire is more forgiving for daily street driving but 40 series is OK depending on how carefully you drive and your road conditions. If you have poor roads best to stick with 45 series or taller. I've hit bad potholes with 65 series tires and done well but I wouldn't try that with a 40 series tire.
Street manners and comfort will vary alot with the tire you choose even if it is 205/40-17. There is a good selection of tires that will fit in that size.
For other cars it's quite a good size using the 17x7" wheel. Good example is a Honda Fit. A 205/45-17 would be too large without rubbing even with stock suspension.
Normally you're right on the money, but this time I don't think so...
there is no "best" tire size for any car. User requirements and preferences bias the equation based on very subjective needs. This means what may be best for one isn't best for another. There are many acceptable choices, you just have to find what really fits your needs the best.
Matt
Matt
09-11-2015 01:15 PM
OutMotoring
09-08-2015 06:27 AM
09-03-2015 03:01 PM
