BBS RD
BBS RD
BBS RD
Offset: 38mm
Bolt Pattern: 4-100 Rec.
Tire Size: 205/45-17 **
Lightweight: 20.3l
I'm thinking about getting these wheels second hand. On the tire rack site it says that they wheels will come with the following at no charge.
(16) Required lugbolt for vehicle
(4) Required centering ring
(4) SMALL CLIP FOR BBS RINGS +
Would I need anything on the above list or can I just bolt on the wheels ? Thanks.
Offset: 38mm
Lightweight: 20.3l
What year car do you have? If you have the wheels nearby check the lug nut holes and see if they are conical or ball seats.
You will need the centering rings....but they aren't expensive at all. You can order them online or pick them up at your local wheel/tire shop. Our hub bore is 56.1mm so you need to get a ring that will convert from it's current size down to our size.
I'm not sure on what the BBS clip is. My guess is that it deals with the centercap and would be coming with the used set.
BBS Rd
I have a 2005 S, The wheels were on a 2006 Cooper. I believe the wheels originaly belonged to NAM Vendor
namotorsports, and were sold to minicloud06 . This was the original AD :
17" BBS RD Rims with Yokoham AVS ES-100 Tires - I'm asking $800 plus shipping - This rim and tire package retails on Tirerack for $1344.00 plus shipping. That's over $400 in savings!
These rims and tires never saw snow, only driven during the summer months. No curb damage or scuffs on the wheels. They have about 12,000 -15,000 miles on them.
Specs:
-17x7 BBS RD Wheels
-Bolt Pattern 4x100, Offset 38mm
-205/45ZR17 Yokohama AVS ES100 Tires
Includes the following:
-Lug Nuts
-Center Caps
You will need new:
-Hubcentric Rings (For those of you interested, you will need new Mini specific hubcentric rings. Those shouldn't be more than $20.00!)
Specs:
-17x7 BBS RD Wheels
-Lug Nuts
-Center Caps
You will need new:
