Torque wrench
Sears is good, also check Lowes/Home Depot, places like that. You can spend anywhere from like $30-50 for a basic up to $400+ on an electronic Snap-On. Just make sure it hasn't been screwed with and has some form of a warranty on it. I'd avoid Harbor Freight for anything requiring precision. A lot of their stuff is closeout items and left overs.
Tirerack has this one for $29.99 up to 150 ft-lbs in 1/2" drive.
http://www.tirerack.com/accessories/tools/tw605.jsp
They also have thin walled sockets and gorilla breaker wrenches
http://www.tirerack.com/accessories/.../tools_all.jsp
I have two Harbor freight torque wrenches (3/8 and 1/2) and both work just fine and seem plenty accurate - as minihume says, just ensure they're stored with no spring tension and, for the home garage, they should last a long, long time... I chose to spend all the extra $$ I saved on MODS...
Just purchased both.
I got mine at Home Depot but you can find much cheaper ones that will also work. Remember to store it with 0 torque after use.
I still prefer the beam type of torque wrench for the home mechnic. Any clicker type wrench requires recertification every so often to be sure it is accurate.
With the beam type as long as the pointed is set at zero you are good to go. No worries about setting it each time and then taking it back to zero between uses.
To make it easier to read I use a Post-It stuck to the scale at the appropriate place.
If you are set on getting a clicker wrench I would highly recommend Snap-On, Matco, or Craftsman.
I have the same Snap-On wrench I purchased new in 1986. It's been recalibrated two times (both good) and is ALWAYS reset to zero after use. I trust it from wheels to gearboxes to head bolts. QJR3200C
Today; probably nearly $250 and worth every penny over the "throw aways" I know other go through 3-4 times.
Hmm...ebay is your friend today!
http://cgi.ebay.com/SNAP-ON-QJR3200C...QQcmdZViewItem
But you have to keep an eye on those tools from keeping them from growing legs and running away to another guy's toolbox.
Snap-On tools. Highest quality.
http://www.jlwinstruments.com/torque-tips.htm
Improper Storage: Storing any instrument in a location that has high temperatures, humidity or in a corrosive atmosphere may cause failures. Storing adjustable click style wrenches above the lowest setting will cause premature main spring wear.
EVMini
09-28-2015 10:20 AM
09-25-2015 12:32 PM
