Question about Pole Position S-03
i use 215/45-17 on a 17x 7 wheel.
go to:http://www.1010tires.com/TireSizeCalculator.asp
Treadwidth: 8.070 in 205 mm
Treadwidth: 8.464 in 215 mm
Rim Diameter: 17 in 431.8 mm
RimDiameter: 17 in 431.8 mm
Rim Width Range: 7 - 8 in
Diameter: 23.45 in 595.63 mm
Diameter: 24.61 in 625.09 mm
Sidewall: 3.22 in 81.788 mm
Sidewall: 3.80 in 96.52 mm
Radius: 11.72 in 297.68 mm
Radius: 12.30 in 312.42 mm
Circumference: 73.67 in 1871.2 mm
Circumference: 77.31 in 1963.6 mm
Revs per Mile: 886.9
Revs per Mile: 845.1
Speedometer1: 60.00 mph
Speedometer2: 60.56 mph
Speedometer Difference: 0.94% too slow Diameter Difference: 4.72%
peace,
d
peace,
d
Thanks guys. Now I just need to decide finally if I want to go 16 or 17 on the wheels. There is a backorder on the 17" EM-9's til Aug. 29. My S just pulled into Southampton today so I'm expecting a mid-August delivery so it would cut it a little close. I was thinking the original 16" and all season run flats would have better resale if they were never used and you know the moment I get it I'm going to drive the hell out of it til it's broken in.
_________________
_________________
Originally Posted by 993
Will there be any "rubbing" issues with the 215/45/17 tire size using H-Sport springs? Thanks.
S03's are considerably wider than their rated widths... for instance
a 205/50 width measured out to about 225mm from sidewall to sidewall.
And yes, starting around 75% wear, they do become very noisy...but
so are Pilot Sports.
Originally Posted by D_Nyholm
Just to add something. The S-03's get pretty noisy toward the end of thier life. I had Pilot Sports on my car and replaced them with S-03s. Overall, they were very similar in performance, though the S-03's were substantially cheaper. Just something to keep in mind...
Originally Posted by kenchan
on which wheels?
Regarding the noise, I believe most of the "V" shaped patterned tires get noisy as they get towards the end of their life.
08-21-2015 12:58 PM
Minibeagle
08-13-2015 10:00 AM
