Question about tires..
Hi this is my first post here, I own a 2004 Cooper (pre face lift) and I have finally decided to go for a 17x7.5 ET 40 rim and 205/45 R17 tires.
My question is if I should go 215/45 instead? I have got some help on the mini2 forum and "MINIAC" said I should probably use 205/45 to aviod rubbing because of the rather low ET 40. From what I can see the positive with 205 is less risk for rubbing, less weight, the tyre will stick out less from the sides of the car. 215: better ride quality and fit on the rims. Maybe I am splitting hairs here I need some input ty .
My question is if I should go 215/45 instead? I have got some help on the mini2 forum and "MINIAC" said I should probably use 205/45 to avoid rubbing because of the rather low ET 40. From what I can see the positive with 205 is less risk for rubbing, less weight, the tyre will stick out less from the sides of the car. 215: better ride quality and fit on the rims. Maybe I am splitting hairs here I need some input ty .
205/45-17 fits rims 6.5-7.5" wide
215/45-17 fits rims 7-8" wide
Tire selection may differ a little between these sizes.
Which tire were you considering?
Any plans to lower your MINI? If so then 205/45-17 is a better size.
Ride quality won't be much affected by just the tire size difference. If the tires you choose are different for each size then ride quality will be based mostly on the design and characteristics of the tire.
Grizld700
12-30-2015 10:47 AM
Navigation & Audio How much power do you get through the Y-cable--and can it be increased?
twriter
10-02-2015 03:14 PM
