Hey Guys, Just got a set of Falken FK-452 215/40/18's and just wondering what PSI you guys are using? Thanks
Tire pressures are based on the weight of the car not the tire size.
It doesn't matter which wheels and tires you have, your door jam has a metal plate listing the recommended pressures front and rear based on your use- either 2 or 4 people.
Use 34 to 37 psi cold pressure front and back, 37 is for 4 people.
You can run a little high for highway driving.
Check pressures when tires are cold, early in the day not in the sun is best or at night.
Tire pressures go up with tires heating up or in full sunlight.
Thanks. I was talking about the wear when I run a bit lower pressure what I am now. Now with the camber plates and the pressures I run now I am getting real good wear. Just a bit more on the inside because of the increased camber.
