235/40-17 for an '07 MCS what offset do I use?
Outmotoring.com lists
8.0 x 17 from 19.8lbs e+20/25/33/37/45/50
Given stock suspension for your MINI the closest to stock fitment would be +37mm offset. +45 mm would place the wheel more inward towards the suspension while +33 would place the wheel farther outward from the wheel well but could also work as long as the tire size is stock tire diameter or smaller.
You can calculate the clearance yourself using-
http://www.wheelsmaster.com/rt_specs.jsp
wildwestrider
12-27-2015 08:20 PM
