Hairline Cracking In Rotors?
Old 03-24-2008, 06:47 PM
Calaway16's Avatar
Calaway16
Calaway16 is offline
Originally Posted by minimike1
toddtce is correct- that is perfectly normal and nothing to be worried about. I'm more concerned about the fact that you paid money for vented rotors that aren't venting anything. Did anyone notice that the vent does not extend to the end of the rotor? Where is the gas supposed to go? I would call up your manufacturer and ask what the deal is?
Unless your doing some serious racing, a BBK is a waste of money (check out mc2 March edition). And if you are going to race, most of the race series out there (SCCA & NASA) require stock OEM rotors anyway. The only series that would allow for a BBK would be the Koni Mini Challenge. I believe that it only runs in teh UK and Australia. Testing has shown that OEM rotors perform at the same levels as non-OEM's in stopping distance. All you need is a good brake pad. (check out www.autoxcooper.com-those guys have it together.)
sorry mate but wtf are you yammering about?
  #27
Old 03-24-2008, 08:28 PM
toddtce's Avatar
toddtce
toddtce is offline
Originally Posted by rustyboy155
Todd can likely explain it better than I can, but it's not something that a stiffening kit will solve. Unfortunately if you're going to be tracking your car on a track with intensive braking points, you need a BBK, or at the very least you need to expect to change your rotors out every 8-10k miles.
Nothing to add really. With pressure on the center of the pad only there's not much you're going to do to change that.
Fordgt4
10-10-2015 10:42 AM
ryGuyMCS
10-06-2015 12:04 PM
Jerome R Jr W
09-29-2015 11:42 AM
09-14-2015 12:48 PM
09-10-2015 10:52 AM
Quick Reply: Hairline Cracking In Rotors?
