Hey all I just got my new 08 MCS. I'm going to buy a set a Work Emotion Kai CR's 17x8. The choices for offsets are 42 and 32 can I run a 32 or do I have to bump it up to a 42? Im on stock settings all the way around. Please help thanks!!
ET32 is 28mm more to the outside....or a full inch. It's not going to look right on a stock car. ET42 is only 8mm closer to the stock suspension (too close on coilovers). Worst case, you can run 3-5mm spacers to clear if it's an issue. If you get ET32 and it doesn't look right, you're stuck.
