Should/could new wheels and tires require alignment?
I just put some new wheels and tires on my '06 MCS and now the car seems to be pulling to the right. It was not pulling on the original wheels/tires. Does anyone know if it is common to need an alighnment after changing wheels and tires, or is it possible that I got a bad wheel????
Thanks for your input
You shouldn't need an alignment. Wheels/ tires don't change the camber or toe of the alignment. Are the tires new or used? Did you check the tire pressure and torque the lugs correctly? Some tires are directional. Did you install them on the correct side? All those could lead to the car pulling to a side
I wanted to follow up on this and let you folks know that this turned out to be a bad tire. Swapped the right front and rear, and voila no more pulling. TireRack is sending out a replacement, and is paying for the mount and balance. So if you get new tires and your car starts to pull, it very well could be a bad tire.
07-16-2020 12:54 PM
sabjcw
08-14-2015 07:40 AM
Rennfahrer555
08-13-2015 09:07 AM
