How to measure brake pad wear?
Is there a simple way (not removing the pads) to measure brake pad wear (how much pad is left)? I remember reading that there was an expensive BMW tool that gave a reading of brake pad thickness but I am looking for a lower cost alternative. I know that you can eyeball it (replace the pad when it is as thick as backing plate), but I am trying to predict
wear for track day planning.
If I could find out what stock pad thickness is when new, be able to measure my current thickness, I'd be able to take a guess on how much longer (or how many more events), that they would last. The last thing I'd want to do is have the "replace pads" light come on after the first run.
If you are going to do a track day. Don't skimp on brakes.
Jack up your car pull the wheels & have a good look at the brakes. For the brake light to come on the pads have to be very thin. I wouldn't recommend using pads that are down 50%.
One other thing. If your brake fluid is more than a year old, change it to a high performance fluid. I like ATE Blue.
Have fun at your track day.
I have 26k on my 05 MCS and started tracking in 2/07. 7 track days to date. Had the dealer look at my pads after the 6th day. He reported I had 8mm left from 12mm when new. My car is stock with 16" wheels. So I guess I'm not going fast enough or braking hard enough to burn through the pads Now I'm just hoping to wear them down enough for the dealer to replace them this fall when my warranty is up!
You should be pulling the wheels & checking your brakes before every track day as a rule.
It's not only for your own safety, but also your instuctors & the others on the track too.
Just my .02 here.
Have fun, be safe.....
I checked
But more inportantly, wrt using the seat of the pants method of comparing to the backing plate I see the baking plate is 5mm. So swapping then is actually pretty conservative. I don't know when the wear sensors go off...I've yet to work on a car where the owner waited that long! but some have said the pad gets 'pretty thin' b4 the sensor is activated.
squawSkiBum
Tires, Wheels, & Brakes
26
03-18-2024 07:21 AM
07-16-2020 12:54 PM
Tires, Wheels & Brakes
08-26-2015 10:28 AM
08-25-2015 09:18 AM
