Tirerack said 215/45/17 will not fit my car. True?
on
So I ordered my 17x7 O.Z. Ultraleggera's with a 37mm offset. They said on the phone that a 215/45/17 will not fit with the O.Z.'s on my 03 MCS. They said that 205/45/17 is the biggest tire size that I could roll with that I wouldnt have rubbing issues. Is this true? I am not dropped now but will have coilovers in the next 2 months and the car will be low. What size do I want. Thanks people...
on
My car was fine with the 215/45's before I lowered it with M7 springs. After I lowered it both front and rear rubbed. I might have gotten away with it with lesser drop springs, but the M7's drop 1.5"s. Also I was running to much neg. camber. I went to 40's and everything is cool . Go with the 40's.
except when lowering and adding camber (which happens from lowering). This brings the wheels in and will (probably) clear. Tire Rack doesn't want the liability and there's a chance it will rub with that offset.
on
on
on
on
Keep in mind the lower you go the more stress you put on your axels. After a certain amount of stress they'll just fail.
17x7ET42 is considered the optimal compromise....splits the diff between stock and aggressive fitments.
I'm running 15x7ET37 on my car, but with 205/50...no rubbing issues but them it's way shorted than stock too
on
Appreciate all the help...
that depends on how much camber you run. if you are not doing camber correction, you probably should look at that before trying to get too aggressive on lowering.
I have Cross coilovers and put my car about an inch lower than stock (maybe not even that much). There's no performance benefit to lowering the MINI...it's all looks. The car has such a short stroke to begin with, unless you are running a coilover like the Cross that maintains stroke regardless of height, you are hurting performance
on
this is a 215/40 right? on what rim width? i'm also having the same tire-choice dilemma with a 17x7.5 +45 wheel and don't now if i can pull off the same look as the Mini below with 215/40 and just Eibach pro-kit springs
on
Some coilover systems (The good ones) allow camber adjustment in the front, others don't. For the rear you will need to install rear camber arms (Unless your car is an 05-06, in which case you will have VERY little adjustment).
on
How much do you look to pay for coilovers with camber adjustment? So in a simple sense I could got with these O.Z.'s, get some camber control, and be able to run a ~1.5 inch drop and not have any issues with a 215/40 tire?
on
Cross/JIC Magic are some of the best out there, but at $2300 you pay an arm and a leg for them. They also have camber plates integrated, full adjustability, and linear springs. These will be more forgiving on the street when dialed back, and will handle better when dialed up.
on
Megan's have camber adjustment, they're linear, and cheap (Under $1000, I think about $850 new). They're going to be stiff though.
Again, so with some camber adjustment, those O.Z. wheels and the 215/40 tires I could get a ~1.5 inch drop without rubbing or major issues?
on
You should be able to get 1.5 inches of drop with those wheels and tires provided you're running some camber. 1.5 inches of drop is going to make you bottom out a few times a day though.
