Brake Job 02 Cooper S
I finally think I have to do my brakes on my 02 S. I'm pretty easy on them so I'm about 80,000km. The front actually look pretty good but it looks like the inside rear pad is worn and the rear rotors look a little rough.
I don't want or need anything high performance. Should I simply get Mini parts (rotors and pads) or is there a better option for comparable money?
Also, for anyone who has done this recently, is there a caliper kit that I should install or should I even be looking at new calipers? Any other likely needed parts? I ask because parts are not nearby and I'd rather have everything I will likely need before starting.
Last I should mention I'm in Canada so if there are any Canadian readers you can point me to a Canadian retailer.
<<http://stores.ebay.com/Morristown-MINI_W0QQfsubZ0QQsclZQ2d1QQtZkm>>
For prices. I went for Brembo rotors and Hawk HPS pads and so far I like them. Good stopping, less dust than OEM and not much more than Morristown charges for OEM. I think the Brembo rotors looked better than the OEMs which I think are ATEs but I am not hard on brakes either.
You should also consider a fluid flush when you do this. Not hard to do and well worth the effort.
Rich
Rich
07-16-2020 12:54 PM
PelicanParts.com
08-04-2015 02:45 PM
