Replacing run flats for regular tires
Tires
It depends on the kind of weather you have on your city.
I changed my MCS2002 tires ( Pirelli Eufori@) for Kumho's Ecsta , first change the front and replace them with runflats, however I bought a spare tire ( small ) put it on the trunk and then bought 2 regular Ecsta. I had Kumho's in other vehicle and worked great. Also I can recommend the Bridgestone Potenza ($$$).
Just be sure to carry a flat tire kit or buy a spare (small) if you will change to regular.
Hope this helps.
Hope this helps.
What wheels do you have? 16 or 17"?
You can replace all four runflats with non runflats easily.
You can search for- "all season" and 205/50-16 if you have 16" wheels and 205/45-17 or 215/45-17 if you have 17" wheels.
These sizes will fit stock suspension.
All Season tires are better wearing, give good enough handling and can be used in colder weather or some snow. If you have heavy snow then winter tires are in order.
For the MCS an Ultra High Performance All Season makes sense but does usually cost more.
If you only do street driving and nothing on the track or at driving school then High Performance All Season can work too.
For 16" wheels and more comfort/longer treadwear a Grand Touring All Season is worth considering.
For more information contact Alex@tirerack.com or Leo at edgeracing.com
07-16-2020 12:54 PM
sabjcw
08-14-2015 07:40 AM
Rennfahrer555
08-13-2015 09:07 AM
minipopkart
08-13-2015 05:22 AM
