Hello will these tires fit on my S-Lites without rubbing on a 2005 MCS ? Thank you for the help.......
If you have stock suspension you will be fine.
They are a little taller than stock but OK.
If you still have runflats on your stock wheels you need to check with the garage or shop you are going to and see if they can dismount runflat tires or not- some shops cannot handle runflats.
