adjusting parking brake
Yep. Unclip the boot from the console and lift it up. You'll see a nut (I think 10mm, but not sure) on the front of the handbrake unit, below the handle. The appropriate procedure is to jack up the rear of the car, and adjust this nut such that there is NO drag on the rear wheels at "zero" clicks and "one" click... but then starts grabbing at the 2nd click. I found that I could take a TON of slack out of mine and it made a huge difference in the amount of stopping power available at 3-4 clicks.
Good to know for those who have fit my rear Wilwood parking brake calipers also. Due to the change in the leverage mechanism on the caliper I've found the handle needs about six clicks to be effective. While sure there was/is a way to take out some of that slack I've personally not done so.
1) lift rear of car
2) pull brake one click
3) try to turn rear wheel. Should be no brake drag
4) pull brake to second click
5) you should start to get some drag on the wheel now
6) you can tighten it as much as possible while still having NO DRAG on the first click.
7) done (don't forget to take the car off the jack before you try to drive... )
07-16-2020 12:54 PM
ebowling
90
08-04-2019 09:15 AM
