What is the widest tire I can fit?
You will get more answers if you post is the Tire/Wheels section HERE. You will need to give them a little more info as well. You might also want to read through that section or do a search as it is a pretty common topic.
The short answer is, if you haven't lowered it at all, you should be fine. Other wise, it depends what is done .
But, those are the pro's over in the other section and can be a bit more specific for you.
I run a 215/35 x 18 on 18x7.5 rims with an offset of 42. My car is lowered on Eibach springs with Bilsteins. No rubbing in the front lock to lock or at the back. Per my bro-in-law (20 yr tire industry veteran), the 215 section width (or any other size) varies from one manufacturer to another, especially, when considering different aspect ratios.
falken 915 but im picking up a set of Azenis 615 in about two weeks, and am keeping the same size.
No, Im not sure what the # are, i have alta lower adjustable control arms out back but the tires have only a slight upper lean in. and i do mean slight. Im not getting any unusual tire wear at all and ive put 10K miles on these tires.
miniust thanks I figured thats what he meant. we all get fat figures typing sometimes. lol
Post what happens. Interesting? I have upper and lower control arms so I am able to get just about any camber angle needed. I just have never stuffed anything bigger then a 215 in the well and before the rear arms it ate my plastic wheel well. At the time I was .075 lower.
i will keep you posted on the new meats. i heard nothing but great things about them, and they are the same measurements as my current ones.
Ive learned to check the actual measurements, not the numbers on the sidewalls.
Mini'mon
08-16-2015 04:15 PM
PelicanParts.com
08-04-2015 02:45 PM
