Strange wear pattern (pads)
So i was checking out my MINI tonight after a somewhat spirited drive and i discovered that the brake pads on the MINI are wearing very oddly.
The outermost edge of the pads are wearing away much faster than the inner-area causing. this worries me because at this rate, the outer part of the pad will wear down to the backplate before the inner part gets even halfway worn. I checked and all of my brakepads are wearing like this.
Is this just how BMW brakes are designed or do i have to make a dealer run sometime soon.
Sounds like your pads are cocked in the caliper. They aren't being pushed in properly by the piston. Does the pedal feel like you have to push it farther than before? When was work last done on the car? You do need to get it taken care of quickly, if you get down to the backing plate it will waste your rotors. They aren't cheap and I don't think that would be covered under warranty. The piston clip probably wasn't attached to the piston properly. Check it out. Hope that helped.
If by outer you mean the part closest to the rotor edge this is a sign of two things: Caliper flex and heat. As the caliper clamps on the rotor it tries to push or spread the caliper and can do so. That means the pads are no longer square to the rotor. Also the edge of the rotor runs hotter then the inner radius as it does more work. Simply sounds to me that you could use some higher level of pad for your intended use.
Location: Car Nut Since 1987, Owner Since Fall 2005, Vendor Since Fall 2007
on
The best way is to remove the wheels and look at the top of them with a flashlight, if there's more pad with backing plate you are good, but anytime there is same or less pad then backing plate it's time to change them IMHO.
pics from https://www.northamericanmotoring.co...ad.php?t=38346
beveled
You do realize that the stock pads have beveled edges right? I think that's what you are seeing.
Here's an almost new front pad I took off my 07...note there's some white paint on the backing plate as the pic was used to illustrate backing plate thickness vs pad material as a gauge of wear
{You'll note that on this pad, when you no longer see any bevel, the pad thickness will be down to that of the backing plate...another wear indicator.}
EBC pads I've used on both GEN1 and GEN2 are similarly shaped. But just for comparison, a brand new set of Honda pads I have sitting on the bench do not have this bevel, so I understand that one might not be familiar with it. Look at the pictures of EBC pads on MINIMANIA and you can see the slanted edges...
2 points for looking and checking tho !
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
patsum
26
05-29-2021 06:29 PM
