Help- new wheel questions.
Hi everyone.
After three complete sets of dunlop run flats (most developed slow leaks), I finally decided to get non run-flats. This was the easy part, now the hard part, the part I need help with.
1. I looked at TheTireRack site, yet every rim I wanted (5-spoke silver $100-$175) only had 2 or 3 wheels available, I need a whole set. Where else can I look online? Any recomendations on reliable, well stocked and affordable wheel sites.
2. Offset: the rims I liked used my tire size (205/45/17), yet the offset was anywhere from 38 - 42. How will this affect my ride (will it rub, is my tire size compatible, change tire size & etc...)?
3. Assuming I keep the same size tires and change the rim, will the gap btw. the tire and wheel be bigger? Does it change the suspension and ride? Do I have to lower the car to make it look right?
Sorry I have so many questions, I didn't know that picking out new rims could be such a pain in the ***.
When I bought new wheels and tires I looked through the tirerack site and finally called Alex. He was able to answer all of my questions and recommend wheels that they have in stock. I would guess he could also give you an idea of when they might have the rims you like in stock.
Alex was a great source of information. He didn't seem to be pushing a sale just helping me solve my wheel problems.
Good luck!
Good luck!
If you are switching from a smaller diameter wheel to a larger one you will see a difference in the ride quality. The tires sidewall must get smaller to compensate for the overall diameter the car has in the smaller sized wheel. This tends to make the ride a bit ruff because the side wall is so thin. A 205/45 is not all that bad, but some people can see it's a bit bumpy.
Leo Barrios
leo@edgeracing.com
800-489-5353 x211
http://www.edgeracing.com
Leo Barrios
leo@edgeracing.com
800-489-5353 x211
on
http://www.discounttiredirect.com/direct/home.do
https://www.edgeracing.com/
http://18racing.com/wheels.html (These are all Rota wheels)
I assume you were on 16s before. A larger wheel is always going to hurt your ride quality and raise your unsprung weight keeping everything the same. There still is a lot of differences in tires where it could end up being better riding than stock. Lowering is mostly a preference, it'll more be a factor of what you are using the car and how much you want to spend. I have stuck with stock to stay SCCA GS legal.
polotska
08-23-2015 09:10 AM
R50/53 R53 Chrono Pack - gauge?
missinmyjeep
08-22-2015 07:13 PM
jrezzo
08-09-2015 10:32 PM
