I am having trouble finding what size lug bolt i should get to run 8mm spacers. I believe the factory size is m12x1.5? is the oem length 28mm or something else? I have found this information on new MINIs but not my for my 04.
how safe are studs? Everywhere I go refuses to install them due to liability issues. Sure its simple to put them in myself, but it just makes me question.
^^ do the OEM lug bolts fit on most aftermarket wheels?
cuz i remember trying to fit rims on an 08 MCS, and the oem conical lug bolts weren't long enough to reach the axle, sans the spacers
no, they don't fit a lot of rims because they are 14 mm diameter (2007+ MINIs) and many wheels are designed for a 12 mm bolt only (the holes are too small). Also (and this was my problem) the bolts have big heads on them and some rims (especially multi-fit rims) require a narrow headed bolt (often called tuner lugs). To make matters worse, there is only one company that makes tuner lug bolts in the 14x1.25 size for the new MINI - Palo Uber - and they are really expensive and they rust.
This is another reason to get a stud kit, but if you are carefull about which rims you buy you can stick with the OEM bolts. Tirerack is good that way - if you select your specific vehicle, the website will only recomend wheels that fit.
There are other companies that make them. I found some on ebay pretty easily.
