2-piece stock sized rotors
Old 01-04-2009 | 03:44 AM
91Eunos's Avatar
91Eunos
OK I did a search and the only thread that came up listed a reference to a broken link...
Does anyone know if anyone's making a stock size lightweight rotor? I'd prefer a 2-piece setup to so I only have to replace the rotor and not the hat down the road.
I don't need more braking power (actually brake torque) per-se nor do I overheat my brakes at the track (finally figured out the Nordschleife after 350 or so laps!) so I don't need bigger brakes or more heat sink capacity--I just want less weight to spin up when accelerating.
I already have studs on the car and typically run 5-to-12mm spacers depending on the wheel setup I'm using so I should be able to adjust for any reasonable brake hat offset issues.
Thanks in advance for any references...
Old 01-04-2009 | 07:10 AM
minimarks's Avatar
minimarks
dba
Old 01-04-2009 | 07:40 AM
miniconcarne's Avatar
miniconcarne
Originally Posted by minimarks
dba
A link: http://www.dba.com.au/2006/new_produ...er_upgrade.asp
Old 01-04-2009 | 08:12 AM
minimarks's Avatar
minimarks
Old 01-04-2009 | 11:05 AM
toddtce's Avatar
toddtce
These shown are the 320mm parts for the R56 JCW parts if I follow the numbers correctly.
I also looked at producing oe sized replacements in two piece a few years ago but the cost just did not justify the gains. With any reasonable two piece set up coming in at about $550pr even the replacement 'rings' don't make this a wise purchase. There are simply too many stock replacements on the market (here anyhow) that can be had for much less money.
The pros; lighter overall weight, lower moment of inertia, possible directional application and perhaps a bit less heat transfer to the bearings. Possible upsize to larger rotors later for different calipers a plus.
The cons; costly, no gains in thermal capacity due to same size overall part, no gains in brake torque or efficiency there, value of directional castings minimal at lower speeds.
Kimolaoha
12-05-2020 10:32 PM
Ryephile
Suspension
113
02-09-2020 04:43 PM
cw40342
10-06-2015 06:07 PM
thebordella
08-31-2015 02:37 PM
BowserKart
Tires, Wheels, & Brakes
08-20-2015 02:24 PM
