new green stuff pads -- now squeaky brakes
recently changed my brake pads to the ebc green stuff....brake dust has decreased dramatically but now i have squeaky brakes. anyone else have this problem with stock mcs rotors? what was your fix? someone mentioned putting some anti-squeak oil/lube(?) between the brakes and calipers which i'm considering b/c the squeak is driving me nuts.
thanks in advance :smile:
Chitown's almost got it right; the newer build MINI's use slightly different pads and have brake pad wear sensors on one front corner and one opposite rear corner. These sensors have no interaction with the DSC, they just give you a dummy light on the IP when the pads get worn down.
Back to our regularly schedulded thread: I had no problems with my EBC Green pads, no squeal or squeak. Yes, they need a bit of a loving touch during break-in, and you actually have to drive your car a bit hard to keep a glaze from forming, so they were perfect for my use.
Good luck,
Ryan
Good luck,
Ryan
on
Here is my personal solution to fixing a squeaky brake problem. Simply get up to a good speed, say 60mph, and slam the brakes as hard as possible. Do this 2 or 3 times if necessary. This will grind away the glaze that forms when brakes are used too gently.
My old VW tuner also suggested doing the same thing in reverse (not at 60mph of course) if the above technique does not fix the squeak.
_________________
"I learned long ago, never to wrestle with a pig. You get dirty, and besides, the pig likes it."
-George Bernard Shaw
_________________
my mcs was built in feb 03 so they ebc green stuff pads fit okay and i believe were installed correctly.
they didnt squeak for 1 week after i put them on....and then i washed my car...and then the squeak started and hasnt disappeared since. i thought maybe the calipers got rusty?
i was told not to brake suddenly for the first xxx miles.
at this point, i might just change the rotors :smile:
Squeal when brakes are off
I replaced my OEM pads with EBC Greenstuff pads a few weeks ago (at 39K miles). They don't squeak or squeal when braking but they do squeal at times when I'm just driving around. It's most apparent when driving slowly or turning. What's that all about! Anybody have a solution?
Alex
Originally Posted by Alex@tirerack
Not being coy, step on them a bit firmer. EBC's dont like gentle braking.
Alex
Alex
Thanks for responding. Fear not, I'm not shy about using the brakes! They don't squeal with hard or gentle braking. The thing is that they squeal when I'm just cruising through the neighborhood with no brakes on at all. It's not loud but it makes people look to see what's wrong. It's like the calipers aren't openning quite enough.
Are you suggesting that a bit of regular brake mashing will reduce the low speed no-brake squeal?
John
Are you suggesting that a bit of regular brake mashing will reduce the low speed no-brake squeal? John
Alex
I think your lacking the anti squeel gel from your pad install. did you get the 2 grey tubes in the pad boxes? These should be applied wherever the backing plate touches steel. Can be purchased as anti squeel.
Alex
Alex
You're an Ace Alex!
Thanks,
John
Alex
Alex
Originally Posted by dominicminicoopers
Alex, My Green Pads (rear) just arrived and they did NOT include any anti-squeel. Looks like EBC is not including it in their packaging anymore, or maybe it was an oversight from the factory during packaging...
i got ferodos ds2500 for my car and mine squeals like you guys, unless i put pedal to the floor and hard brake...... but then lurches my passengers forward.... hm...
it's sometimes so embarassing to brake in parking lots because they squeal
anyways, as a friend told me you got aftermarket pads because of performance and dust content.. not for noise... but i guess that's more true with the ferodos
Alex
