Old tires, new tires and fitment
on
After reading several threads on old tires, I realized my tires are old. I have a set of Yoko AVS ES 205x50x16 purchased in spring of 2003. I have around 6.5k on the tires, warm weather use only and stored properly.
Tread is good and sidewalls look good but I am now concerned about the age. Should these tires be replaced?
If I do replace the tires, what sizes can be run on my wheels? The wheels are SSR Comps 16x6.5. Mini is lowered around 1" using H-Sport springs. I am in the process of installing a boatload of mods - head, cam, clutch, LSD - on top of what I already have - header/cat, exhaust, CIA, intercooler. I am thinking a wider tire would be better able to handle increased power.
If I am maxed out with my current wheels, what would be a good option since I want to stay with a light wheel. Sent an e-mail to Alex, but will end up calling him to hash out details.
Thanks,
Thanks,
They could be even older than you think. You can determine their
birthweek from the last 4 digits of the DOT tire id #
http://www.tirerack.com/tires/tirete....jsp?techid=11
for instance, a number ending in 4102 would be the 41st week of 2002.
Some companies used to reccomend replacement at 10 years, but most
now reccomend replacement once a tire is 6 years old.
I'd replace them now and I'd stick with 205/50/16.
How about these? Dunlop Direzza Sport Z1 Star Spec.
http://www.tirerack.com/tires/tires....e1=yes&place=0
on
