Recommended replacement pads?
The dealer just replaced my from pads and rotors under warranty (20,000 miles FYI). Now that I have new rotors (and white wheels), it's time to replace the front pads with something less dusty.
My priority is (1) low dust (2) no squeal (3) cost. I keep thinking I'll track it or AutoX but frankly it hasn't happened yet so I'm not planning on it. Consider this a daily driver (but if there are pads that aren't dangerous on the track and meet my other needs...).
Also note that I'm only planning on changing the front pads as the back still have a lot of life in them and will therefore still be covered (at least for another 10 months)
Recommendations?
Thanks!
Recommendations?
Thanks!
Pad's
I recommend for a street application, Bobcat pads by Carbotech check
out their website www.ctbrakes.com
Last edited by minilites; 02-03-2009 at 08:03 PM. Reason: wrong address for carbotech brakes
I've use both CarboTech Bobcats and Hawk Ceramics - both work well and have very low dust that was very easy to wipe off. The Hawks are less expensive but wear your rotors faster - and did wear out my rotors pretty quickly. The Bobcats cost more but are easier on the rotors, and perhaps have a little better modulation. Both will stop your car, and both will feel VERY different from stock... they don't have the initial "throw you into the dash" bite of the OEM pads, but instead they bite a little with light pedal pressure and harder with firm pedal pressure. Panic stops will still kick in the ABS. This provides for better control over stopping, but takes a little getting used to once you're accustomed to the OEM pads.
out their website www.carbotech.com
on
I've use both CarboTech Bobcats and Hawk Ceramics [... ] Both will stop your car, and both will feel VERY different from stock... they don't have the initial "throw you into the dash" bite of the OEM pads, but instead they bite a little with light pedal pressure and harder with firm pedal pressure. Panic stops will still kick in the ABS.
Edit: If you think you might do track duty on whatever pads you get, I can't recommend the ceramics - I still remember the smoke coming from the front brakes when I was bedding them in. I can't imagine they'd last long on track.
just like non ceramic pads, there really isn't one pad out there that does it all....ferodo is probably the closest thing....but the op is worried about $
squawSkiBum
10-02-2015 09:21 AM
thebordella
08-31-2015 01:37 PM
