Just wondering what the slimmest profile BBK is out there? I'm currently running the standard AP Racing set-up but may need to change it out as I'm worried my new wheels will not fit over them without the use of 10mm+ spacers, which I don't want to do.
Texas Speedworks makes a big brake kit that fits under 15" rims. It is a thicker disk and larger caliper that dissipates heat really well like the larger brake kits.
He's getting 18s.. He's worried about the caliper thickness with regards to the offset of the wheels..
How much more does it protrude than the OEM setup? Say, on a wheel with a flat face OEM had a 0mm gap, what size spacer would be needed to fit the DP6 13" kit?
I'll run the numbers on it based on the aluminum hats and relative to where the wheel sits- this is the common spec. The DP6 is however lower profile than the stock caliper, it just depends on how deeply inset the rotor is compared to the stock one.
