Dyna Plug kits
it's what I use
I've run a tire a good 15,000 after using it...a run flat too
only time it didn't work was a puncture that was vary much on an angle. the nail didn't go in straight and several plug attemts left me with a small leak yet. But every other time it worked fine. I carry in both MINI (with pump and pliers) and have another in the garage which I've used on the other cars
I have not had to use one yet but noticed they are smaller than a standard plug.
Ditto on what they said!
I carry the Dynaplug kit, a pair of pliers, a pair of side-cutters and the compressor. Only used it once, but it worked great.
Plus, I ordered the kit directly from Dynaplug. It was shipped overnight and I got a call from them to make sure it had arrived. Good people!
Jim
Jim
I had screws in the two back tires of my non-MINI. Both were plugged with DynaPlug a while ago and no air loss can be detected.
You can pick up DynaPlug in Harbor Freight Tools stores. If you wait a while there will probably be a coupon. They also have replacement plugs in addition to the tool.
I've used other plug kits in the past, and only use the Dynaplug once, but have been very happy with it. Really nice to not have both a ream and plug sequence.
I have also used he Dyna Plug in the two years after my prior post.
It was very easy to use and only required one plug for a screw hole. Because the material is so much thinner than a standard plug I was concerned but the Dyna Plug worked just fine.
I was very happy to have the Dyna Plug when I needed it.
Thinking I'm gonna pick up a Safety Seal kit too. That way I have the best of both worlds. I've used a tech tire kit for years on our fleet vehicles and have plugged dozens of holes and it has never once failed me. I like the small Dyna plugs for small holes but don't think I wanna go stacking them either when I can get a vulcanizing rubber plugs in the bigger holes
bump as I have some Q's.
I tend to find more screws than nails which I figure make a larger hole. Think this would work for screw holes? Those of you who have used two plugs in the same hole - did it ever leak?
The air compressor? How long does it take to bring a tire from ~20lbs back up to 32+? It looks small which is great for storage but I don't want to wait 45 minutes for it to fill the tire. I have a larger 12 volt one that would probably be faster but take more room.
I already have a set of Dunlop Startechs on Oz Ultraleggeras waiting for my next mini which shows up in ~ 3-4 weeks.
The compact compressor I have brings a tire from 0 to 35 PSI in about 5-8 minutes depending on the tire size (my wife has 235/18's on her Santa Fe which take a little longer). It all depends on the specific compressor and how many CFM it pushes. If you are concerned about it just check the package and make sure to note the CFM at ?? PSI. More will fill a tire faster.
I have used the plugs in two holes with the oldest about 2.5 years old now and no leaks.
AZN Optics
08-21-2015 02:02 PM
08-19-2015 12:51 PM
08-19-2015 08:27 AM
