LY/B and wheels options.
Given the black roof and mirrors-
Darker wheels would work.
All black flat or gloss
Black with polished lip
Dark anthracite
Dark Gun Metallic
Dark silver
Yellow powdercoated or OEM LY painted
16x7
17x7
If you lower you should watch not to make the tire too much taller than stock. Limit about 24.4" tire diameter.
http://4.bp.blogspot.com/_Z0X6H-A2hs...w+mini+too.jpg
Dark anthracite
Dark Gun Metallic
Dark silver
16x7
17x7
what do you guys think about this setup?
http://www.tirerack.com/wheels/MiniW...0701840213217B
You can make the color LY/B
If 18x7 wheels then
Tires
215/40-18
Yokohama AVID W4S $126 each
Ultra High Perf All Season tires
400 treadwear 24.7" tire diameter. Works with stock suspension
Otherwise if lowering then
215/35-18 is fine. A little smaller than stock tire diameter for more clearance.
Bruce/Fl
08-28-2015 11:59 AM
