Stud conversion
Stud conversion
So I am putting on some Enkei OR25s and I am checking to see if these are what I want to use to get them on. http://www.autoxcooper.com/tsw_stud_kits.html
I just want to make sure that the nuts will fit in the holes with the adaptor so that I can tighten them down. Woul kinda be pointless if I couldn't get them on. Tahnx for the help.
Location: Car Nut Since 1987, Owner Since Fall 2005, Vendor Since Fall 2007
on
[SIZE=3][FONT=Calibri]Well I cannot find any decent specifications on the OR25. If it is drilled for M12 clearance and has a 60 degree taper seat then our M12 or M14-M12 studs should work. If it is drilled for M14 clearance and has a 60 degree seat then our M14 studs should work.[/FONT][/SIZE]
10-01-2015 12:13 PM
09-29-2015 12:11 PM
