Resetting TPMS
on
So you are having a problem reseting the TPMS, or when you reset it it gives you another error? Its you just can't get it reset, you have to turn off your car and then just turn on the ignition without pushing in the clutch(if you have an auto I don't know how to do that) then go into the info screen and go to reset the TPMS, when you hold it down and it says reseting then just start the car and drive off it should reset in a couple minutes.
simo711
09-29-2015 11:53 AM
