TPMS from R53S to R56S
As far as I know, they will not work. Reason (if I remember correctly) the sensors from R53's up until Jun of 06 monitors tire rotation to sense if it is missing air. From Jun 06 on up it measures the actual tire pressure. You can buy the sensors from Tire Rack, they sell the correct ones and they are the lowest on price. Most places have them listed as model year 2007 on up. Hope this helps!
Correct me if I'm wrong but there are no sensors in the R53 wheels. I believe that the "sensors" actually only measure the rotation of the wheels and if they are off by a percentage then the "alarm" is tripped.
While you can buy sensors from Tire Rack or any MINI dealer, you have to make sure that your wheels have a place for the sensors to mount. I think wheels that are compatible have a flat area where the sensors fit. Depending upon how old the wheels are, they might not be compatible.
There's always the option of running without the sensors which isn't all that bad.
on
trw92a
08-26-2015 01:47 PM
08-19-2015 12:51 PM
08-12-2015 01:24 PM
