Tuner lug nuts? What are they?
They make the wheels and tires perform better and increase grip. JK...
Many aftermarket wheels do not have a lot of room to fit large impact style sockets over the stock lug nuts. Tuner lugs offer a smaller diameter head and typically use a special socket. For me I just stick with factory lugs and tell the tire shop people they can't use an impact socket as it won't fit and will scratch the rims...
It's not just the socket that won't fit - stock bolts are just too big for some of the tuner style wheels. Tuner lugs are usually a socket head rather than the standard hex head.
'07's and up use 14mm x 1.25 thread, which is rare. They are NOT 1.5 that is found everywhere. I was told that only one company made them and the cost was about $120/set. I found some on Ebay for $35 - new.
A Bit of a grumpy answer
tuner lugs are marketing. What you want to get is the right lug with the right threads, the head that is correct for the wheel, and the correct shape.
you can buy "tuner" lugs that are total crap and just look good (or don't even do that), or you can get "tuner" lugs that are made of quality materials with the proper dimensions and the like.
Really, I think the label just means "non-OEM".
Matt
Matt
My summer wheels require tuner lugs. The stock lugs just don't fit.
If you have a 07/06 build or later it is a PITA, because as mentioned above they are 14mm x 1.25 which is impossible to find. I have a 09/06 build R50 and I've only found two places that have them - one escapes me (the tire shop ordered them from them) and the other is Palo Uber (if you want rusty ones).
on
Normal lug head:
tuner lug head:
