Need pictures of 17's and 18's on R53's
So I have decided on the wheels I want, but now I am torn between going with the 17's or 18's. I am pretty sure I want to go with the 18x7.5's with a set of 225/40's on them. First off, will this 18" wheel/tire combo fit without rubbing? Second, will I be able to lower it with this combo if I decided to later? I guess my other option would be 17x7's with a set of 215/45's on them.
I am pretty much only concerned with looks as this is my daily driver. So I just want what ever is going to look/fit the best. Anyone have any exerience here?
Oh, and these are the wheels I have just fallen in love with.
Tire diameter is too all at 25.1" and won't work for any lowered suspension.
18x7.5 could work, what offset will you use? +42 to +45mm offset could work. Use a tire with less than stock tire diameter or about 24.1" or less.
225/35-18 would be a good choice. Fits rims 7.5-9" wide. Tire diameter of 24.2". Good tire would be Goodyear Eagle F1 Asymmetric for best handling.
If you want good tread appearance and can put up with a bit more noise then Yokohama Parada Spec-2 and BF Goodrich g-Force T/A KDW2 are nice looking.
For better value and street comfort-
Yokohama S.Drive Ultra High Perf Summer tires 300 treadwear $137 each
In 215/35-18
Another good value and good comfortable street tire is-
General Exclaim UHP Ultra High Perf Summer tire 380 treadwear $93 each
23.9" tire diameter is small so more clearance for lowered suspension but more wheel gap than stock. This tire also comes in 215/40-18 which is a little taller than stock- OK for stock suspension but a bit tall for lowered suspension- still possible.
If you have bad rough roads think about damage to rims and suspension if you have lower profile tires like 35 series sidewalls.
andrewjg1994
01-29-2021 07:45 PM
O4mcs
08-06-2015 05:42 AM
