5mm spacers - need wheel bolts?
I've searched all over the forum... I'm just trying to figure out if I need a wheel bolt kit for a 5mm spacer? It seems some people don't use them, and some people say it's necessary... I'm just trying to solve a rubbing issue with my new tires. One side in the rear rubs on the struts over bumps, and if I have a heavyish load in the back.
ive run 3mm and currently running 5mm spacers with oem bolts.
i keep them torqued at 86lbs and check it every couple of weeks JIC.
i autox and they have never worked their way off.
does this mean it's ok to do it? i dont know.
does it mean that it's dangerous? i dont think so. i check my lugs pretty often.
That would work, since the backside of the wheel mates up with the surface of the hub. See how much of the bolt protrudes through the wheel, subtract 5 mm, and then see if that still leaves you with 18 mm of thread to engage the hub once the spacer's installed.
It's something you should do.
I was at a tuning session once where one of the car owners had aftermarket wheels with thin (don't remember thickness) spacers and the combo of the two left about 2 turns of the lugs holding the wheels on. Not safe at all.
Anyway, this is one place where you want good thread engagement.
Matt
Matt
I would(and do) use studs like DrPhil suggested, but if you don't want to go that route...you can get longer lug bolts from Turner...
http://www.turnermotorsport.com/html...mw-wheel-bolts
...you have to figure that the stock lug bolt is that length to be safe with the factory wheels without additional spacers. This is one area where you do not want to be messing around...buy studs or longer lug bolts and be safe.
greystone (06-03-2021)
The backside of the wheel actually mates up to the rotor. The threads don't start until you get to the hub. So subtract the thickness of the rotor face as well.
I needed to run some long Tuner Lugs, so I ordered them from here since they had different sizes available..
Click Here
Click Here
the spacers will sit flush to the lug surface leaving the hub exposed for the wheel to rest on. i cant remember the exact dimension of the hub itself but IIRC it's 8mm. so with a 6mm you're leaving yourself with 2mm for the wheel to center on the hub.
you might be better off looking into custom spacers that make up for the hubcentric lip:
http://www.skulte.com/product_info.p...products_id/57
You would want to find out what the center bore diameter of the spacers are, I know that the R53 is 56.1 so you would want them to be that size, if not you will want to get hub rings that would have a outer diameter that matches the diameter of the spacers and an inner diameter that matches the size of your hub, that way they sit snug on the hub.
Here are my custom spacers and a diagram of with measurements..
If i had the money, I'd be buying some made for the mini anyway with proper centerbores. But I don't, which is why I'm asking about the universal ones. Is there any harm to using ones that do not have the proper center bore? Once they get bolted in with the wheel, they'll be centered anyway, right?
You will have to line them up as best you can, the hub rings sit on the lip that is built into the spacers so that the wheel sits correctly on them, before I got the hub rings and simply lined them up by eye, under acceleration I was able to feel that they were not lined up properly.
If your spacers are thin and the wheels have the same center bore as the hub, the spacers I guess could float since the hub is supporting the wheel.
Is it even possible to use universal spacers if you don't have a stud conversion? I have to see for myself, I'm having a hard time visualizing it. I've had my wheels off of my car plenty of times to know what it looks like, but I suppose I won't see until I do it. Just wanted to know if there were any glaring, dangerous things I needed to look out for.
Sucks because I have a friend who has a metal lathe... he could totally build me some spacers, if he didn't live so far away.
