Lug bolts?
Lug bolts?
Thanks to Craigslist, I came upon a nice set of ASA AR1s (17x7, 4x100) for my '03 MCS.
My question is pertaining to whether or not I need to get different lug bolts. Do I need them or can I use the OEM lug bolts?
They're a fairly common wheel, so I figured those of you with the AR1s could point me in the right direction.
If it does need lug bolts, what would be the best/most inexpensive place to find them online?
Thanks!
Thanks!
Bolts are fine but you need concentric rings: http://www.tirerack.com/wheels/Wheel...All&sort=Brand
From The Tire Rack website.
Included Wheel Installation Hardware
The wheels you chose are engineered to use Original Equipment lug hardware and therefore lug hardware is not included with your order.
Hardware included at no additional charge:
(4) Required centering ring
Thanks so much for the information!
Would a wheel/tire store be able to order them in for me? It appears that I can't quite order them off of tirerack since they're an included item!
Any idea on cost? They seem inexpensive enough.
And they just go over the hub behind the centercaps? Sorry, I'm in unfamiliar territory!
Any idea on cost? And they just go over the hub behind the centercaps?
Alex
EVMini
09-28-2015 10:20 AM
