I think I've seen reference to this before but I'm not sure. If one wants a smoother riding tire, can non-run flat tires be mounted on the same MINI wheels that originally came with run flats mounted ? Or does one have to buy a new set of wheels to mount regular tires ?
You can put non-runflats on the OEM runflat wheels. I had it done. Kuhmo ECSTA V700 on my OEM 16" rims. One of my runflats found a couple nails in the sidewall and I didn't want to take my Azenis off the Enkei's and put them on the OEMs. So new race tires on the heavy rims...whynot...
Oh, I should have mentioned. If you do have them done, you want to find someone who has done runflats before. They are a PAIN-IN-THE-BUTT to change out. Don't spend more than around $15 per wheel.
