Spacer question...
on
Spacer question...
I have a set of 215/35/18's ordered with a new set of wheels ordered as well. Wheel has a 45 offset and the wheel dealer is telling me I need 10mm spacers and new lug nuts. No real surprise from what I've read here and also I want to get the new wheels flush with the fender.
In making arrangements with local tire shop the GM of the shop is telling me every time he does a spacer addition the customer more often than not comes back complaining of vibration. This is in general not just Mini's
Anybody else run up against this?
Thanks!
Thanks!
on
It's a R56. Whether they fit or not is not the question (at least I hope it's not a issue!) According to wheel dealer it should
What I'm asking for is feedback on if spacers on Mini's cause allot of vibrations. Have not read it here and hearing from tire installer today was the first. As I said his experience was in general, not Mini's in particular
on
minimarks,
Looks like we hit "send" at the same time.
I'm getting the "system 4" spacers
http://www.tunershop.com/Wheel_Space...48&modell=3207
with set of appropriate lugs
why are you getting longer lugs?
the system 4 is a wheel spacer that uses your old lug positions to hold the spacer in and provides you with new lug positions for the wheel to bolt up to. so you wouldnt need longer lugs unless they recommended you get longer ones?
if you got the system 2 or system 5 i could see the need for longer lug bolts
I see your MINI is an R56. Mine is an R53, but I've been running 215/40/18 tires with 18 x 7.5 wheels, a 45mm offset for over a year. No rubbing, NO SPACERS.
![Nod](https://www.northamericanmotoring.com/forums/images/smilies/nod.gif)
Maybe the 56 is different, but I'm not so sure about that.
![Confused](https://www.northamericanmotoring.com/forums/images/smilies/confused.gif)
I'm not so sure that your wheel dealer didn't BS you into buying something you didn't need.
Maybe the 56 is different, but I'm not so sure about that.![Confused](https://www.northamericanmotoring.com/forums/images/smilies/confused.gif)
![Roll](https://www.northamericanmotoring.com/forums/images/smilies/roll.gif)
on
I am surprised they suggested spacers as well. BUT they will make the car look much better and the fenders will have a more "filled" look.
We carry the H&R and I would recommend them if you want a quality hubcentric spacer. Bolts are available as well.
Most importantly though, post up some pics once you have the wheels on the car!
Good luck!
Good luck!
on
8.5 aint gonna work. I'm pushing it with 7.5" rim with 225/35/18 and 5mm spacers. For custom spacers go to www.wheeladapter.com and for studs go to Texas Speedwerks
![](http://i28.photobucket.com/albums/c223/relicskateboards/006.jpg)
If anyone wants to play around with wheel sizes, try this:
http://www.1010tires.com/WheelOffsetCalculator.asp
Or Tire Sizes:
http://www.miata.net/garage/tirecalc.html
Rob
on
thanks for all the feedback guys.
All my research and question asking comes down to that this *should* work
I got turned onto these wheels seeing them on a Mini here on the forums. Also on the Schmidt Wheels site they have several pic's with Mini's with these wheels installed.
On the site that I found the wheels for sale in the US they offer a tire/wheel combo with these wheels using 215/35/18 tires. I read somewhere that 215/35/18 tires will support a 8.5 width wheel
Think minimark hit it on the head that I gotta give it a shot
on
So many of you are quick to say "it won't work" yet have any of you tried fitting wide wheels or searched around?
18x8.5 ET35 will work from a clearance standpoint, you may rub like hell though (depending on how slammed you are) without some nice camber. Gonna look sweet.
Check out m|u for the wide/low stance MINIs.
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
