Camber
Camber
I am about to go get my alignment and i think i am going to have them camber all of my tires to -1. i have stock rear end. what would you guys suggest to set the camber at for all 4 tires. i'm a pretty aggressive driver and i race auto x often But i do use a set of race tires for auto x.
If your car's suspension is stock, it will depend on the year of your car whether or not the camber is adjustable. Seeing that you joined NAM in 2008, my guess is you have a R56 MCS which allows for some camber adjustment front and year. I would suggest as much negative front camber as you can get up to around -2 for the street. For the rear, between -1 to -1.5 would be good. You probably want the rear camber less negative than the front.
I have 2006 Cooper and would also want to find out if camber is adjustable on stock suspension. I took off the wheel and was peeking around but found nothing that would clearly indicate that stock suspension can be adjusted.
Will I need camber plates up front to do this?
for the newer generation MINI's there's a little alignment plug that can be removed to slide the strut tops in a bit. quikmini describes -2° but i dont think that's possible without camber plates.
If you like to Auto-X and are not worried about being bumped up a class, front adjustable camber plates will make a hugh difference. You can adjust more negative (such as -3.0) for Auto-X and back to -2.0 or less for street. If you keep stock springs, you should be able to adjust the rear from about -1.0 to -2.0 degrees. You probably want to stay about a 1 degree less negative in the rear compared to the front (such as -2.2 front and -1.5 rear). With my JCW springs (about 1/2" shorter than stock), I can adjust my 2006 MCS to about -1.5 but I can not get any less negative due to the lowering which causes additional negative camber in the rear. Lowering does not effect the front camber. The other option for more negative front camber is the IE fixed camber plates which add -1.25 to whatever camber your car has stock (varies from car to car), however it is not adjustable. For Auto-X, no one would even know you had the fixed camber plates if you did not want to tell.
A lot of hwy miles will show uneven wear with too much camber.
I only need to run -1.3° front and rear to get perfect wear on my Hoosiers, however my car also has low Cg and very high roll stiffness. On a basically stock MINI, around -2° front and -1.5° rear is more in line to get good tire wear on-track. With snid running over -3° camber, he must have massive body roll to rationalize such high camber angles.
Running 42 lbs. of pressure all the way around. Stock 2005 S with sport suspension. Well lets just say it looked like I spent more time on the sides of the front tires than the tread.
Seriously looking at camber plates for next track day.
Maybe it was me. Thought I may have been turning in to aggressively.
Judge for yourself.
Judge for yourself.
fkrowland
09-30-2015 10:30 AM
