H&R Wheel Spacer...I am confused
So I just received a set of H&R 5mm Trax+ Wheel Spacers Part# 1024562. 100/4, 56.1mm center bore for my 2005 Mini Cooper S. Needed spacers to fit over the TSW MDM BBK for my winter 17" S-Lite Wheels
However I have 2 questions:
-1) The dont have the lip on them where I would think they would "center" the wheel..which I believe would be called "hub centric"? They instead are beveled/counter sunk.
-2) Which side goes towards the brake rotor/hub? The beveled or flat side?
Is this right?
http://www.turnermotorsport.com/html...UCT_ID=1024562
Is this right?
Looks like maybe the protruding hub centering ring is only on wider spacers like these...
http://www.promini.com/product-exec/...arch_model/100
"All RaceMax wheel spacer thicker than 12mm are machined to include the protruding hub centering rings which will always center your wheel for proper wheel balance."
Correct, spacers need to be thick enough in order to have enough strength to support the hub centric lip... I am actually running 11mm Custom Front Spacers, and I think that's the thinnest they can be and have a machined lip..
You can get custom spacers from Skulte performance, that Is where I got mine machined..
Otherwise, you have to line them up visually and tighten them down centered..
![Wink2](https://www.northamericanmotoring.com/forums/images/smilies/wink.gif)
what is 8/10's?
SosoMINI
11-22-2015 03:17 PM
kurosh
08-27-2015 11:54 AM
Mini'mon
08-16-2015 04:15 PM
