Anyone on Breyton GTS-R yet?
#176
OK all.. FINALLY I think I am ready to pick these wheels up from the refinisher. I had them PAINTED using the correct MINI White Wheel Code and had the center cap painted black since you get silver with your order.
JCW cars have to order 18s as we know and I was able to get the 5mm spacers from Turner Motorsports.. Not sure if I am allowed to say that but thought it may be helpful. They are hub-centric.
I will post pics up on Thurs when I finally get them on.
#178
Is there anyone with a dark silver Mini that has the grey Breyton wheels? If so could you please post any pictures you might have. I am consered that the Breyton grey might be close enough to the dark silver that it looks like you were trying to match and missed but it may be enough different that the contrast of grey's will look good. BTW I have a set of black wheels OZ Alleggerita's and I do not like the black color wheels on my Mini and I also have silver OEM challenge wheels that I like better but are too heavy.
#179
Do you have a JCW? Apparently they have a different thread pattern so I am told? If true does anyone know where I can get longer bolts?
#180
Here are a few examples that should get you close. The first two are matte grey Breytons, and the last three are for color only.
Hope this helps
#181
Here is the link Alex sent me. I got the 5mm spacers and these bolts.
Mini Cooper 5mm Spacer Lug Bolts
I would love to find them in black, but they are silver at the moment. May take them off and spray paint them for now.
#182
#183
#185
Yep same here.. I have a private message and a thread question for a guy that has the WC50 and put 18s on. He is on this thread too I believe. Hopefully he will see this and be able to respond and let me know if for our set up he needed longer bolts. I have the spacers sitting in the dining room ready to go tomorrow.
#186
I just put some 17" GTS-R's on my 2011 MCS PW. Man what a difference. They look awesome. I went with 215/45/r17 s-drives.
I have a set of NM Engineering springs right now and I am deciding if I should put them on. I am not worried about dropping it, but I am worried about rubbing if I put people in the back seat. Although there is about 2" space from the wheel to the top of the wheel well, as the rear wheel well tapers down to the bumper it crosses the tire. My concern is with rubbing across the tire in this area. Anyone running 215/45/17's with a spring drop that can comment? I'll get some pics up tomorrow.
#187
I'm on KW V2's-TSW. Purchased from WMW. I'm not sure how much drop you will get with the H&R springs. The GTS-R are ET40, and I'm running a 5mm spacer with the 215 tire. I trimmed the front arches a little, simple job.
#188
#189
#190
#191
I've had no issues with spacers. I think you should run something to reinforce the strut towers, I think it is a definite weak area. The Mini just doesn't have that much suspension travel and they get hammered.
#192
Blue Toy,
Thanks for the pictures of the mat grey Breytons on a dark silver Mini. Can you tell me if the mat grey finish requires any special effort to clean the brake dust off. I am thinking that a mat finish might not be as smooth as a bright or glossy finish and want to hold or get the brake dust imbeded into a non smooth finish. Please let us know your experince with this wheel finish.
#194
What's funny is that I've put the 5mm H&R spacers in my shopping cart more than a dozen times but just couldn't justify going through. Spacers + Longer bolts would come out to $150+ with shipping.
Right now they're sitting at ET40, and look pretty good imo. New tires are on the horizon soon, and I'll prob go with 215's and go from there if I still want spacers.
#195
Blue Toy,
Thanks for the pictures of the mat grey Breytons on a dark silver Mini. Can you tell me if the mat grey finish requires any special effort to clean the break dust off. I am thinking that a mat finish might not be as smooth as a bright or glossy finish and want to hold or get the break dust imbeded into a non smooth finish. Please let us know your experince with this wheel finish.
I got that pic off M/U. Not sure who owns it. If I had to guess, I would say 18's, because that is an R56, and the wheel well is slightly larger.
#196
#199
