Wheel rubbing with 17x7s?
on
My front passenger wheelwell has some cracks in it on the front side and the back side. I run Enkei 17x7s with appropriately sized BF Goodrich tyres. The dealer isn't covering the wheel arch under warranty because they are blaming the aftermarket wheels and tyres on the cracks. Does this sound like it's the cause or should I pursue the issue further? The weird thing is that these very wheels are the same wheels that my boss ran on his R53 JCW for a couple of years to no detriment. I'm the second owner and to my knowledge the previous owner ran only the stock 5-stars with run-flats.
Thanks!
Thanks!
Is your suspension stock? What is the overall offset of the wheels (with spacers if you're using them)? What "appropriate" size are the tires? Are you sure that the damage occurred since you bought it?
Unless failure of a stock suspension component led to the tire/wheel arch contact, this does not sound like a warranty issue to me.
If the damage is limited to the plastic trim pieces, they are vary easy to replace.
I am running 17x7 Enkeis' as well. Offset is -48 in the rear, and -43 in front with a spacer. I am lowered on coilovers and had to trim both front and rear wheel wells. My font is so lowered that it actually srapes on the inside of the hood, and the rear hits the body of the car over high speed bumps.
The fronts are very easy to trim with a dremel without removing them, and the rear should be removed to make the dremeling easier and safer.
on
on
Kimolaoha
12-05-2020 09:32 PM
devicemanager
06-17-2016 06:18 PM
bluefox280
08-29-2015 06:52 PM
