Painted my wheels, calipers w/a little DIY and pics astro black MCS w/graphite wheels
Hey everyone, last weekend I painted my wheels, calipers and the chrome grille surrounds on my MINI. I used Duplicolor self etching primer, Duplicolor graphite wheels paint, and the Duplicolor clear coat.
My DIY is very similar to everyone elses
So heres the pictures of the wheels and calipers on my 2007 astro black MCS. I will also say that the wheels are not smooth and glossy, the graphite paint seems to have a little bit of a metallic to it so it is just slightly textured, the clear helped even this out but just know that its not as smooth as a powdercoat or a gloss paint. I painted the grill surrounds as well and it was quite easy. Used 2-3 coats of primer, 3 coats of astro black match paint from minspeed.net(didn't really match well, its too black) and then 3 coats of primer. Came out really well except for the paint color. Also keep 1000 grit wet sandpaper handy to sand any primer/paint/clear that you mess up.
![](http://i292.photobucket.com/albums/mm15/dwebber18/MINI%20after%20paint/9fd160aa.jpg)
![](http://i292.photobucket.com/albums/mm15/dwebber18/MINI%20after%20paint/582e09fa.jpg)
![](http://i292.photobucket.com/albums/mm15/dwebber18/MINI%20after%20paint/75d7ff35.jpg)
- I sanded the wheels with 320 grit sandpaper
- then wet sanded with 400 grit sandpaper to remove everything and get it down to a nice dull finish.
- I then used the duplicolor prep cloth that removed all oil, grease, dirt, sanding dust and everything else from the wheels. I had a tack cloth but didn't use it much as its just sort of nasty and sticky and I didn't need it.
- I used the index card method of protecting the tires, it worked well but was a little time consuming when you are turning the wheels over. I started with 2 coats of primer on the back, waiting 10 minutes between coats and hit the front with 3 coats of primer. I then did 2 coats of paint on the backs then 3 on the front. Remember to use very short quick sprays to keep everything even and smooth, resist the urge to just go at it cause it will run and look like crap. after the paint I did 2 coats of primer and 3 on the front finishing with a semi wet coat of primer.
![](http://i292.photobucket.com/albums/mm15/dwebber18/MINI%20after%20paint/1e43b53c.jpg)
07-16-2020 12:54 PM
dyeLucky
08-07-2015 07:10 AM
O4mcs
08-06-2015 05:42 AM
