Again... hard to tell because of the picture size, but SSR sold a 7-spoke wheel that looks very much like those. A buddy of mine has 18" versions. I believe they are no longer in production...
A number of companies have made 7 spoke wheels that look like those.
Ravspec.com - a NAM vendor and I've used them twice for my wheels (one Work set) and have been very happy with them.
Haha. Thanks roofa. I just found them in the vendor section and e-mailed them. What offset should I be looking at for an 18 x 7.5? I plan on going to coilovers and do not want to deal with rubbing/strut issues.
+42 to be safe or +35 if you want the wheels flush with the fender or you could run the +42 with spacers to give you that flexibilty.
if your putting them on your 08 in your sig, then a et38 is pretty close to the fender on the r56... mine are 38 and with the 17x7.5's if i go larger than a 205/45 tire (depending on brand) itll rub on bumps
this is with the rear jacked up some due to the ebrake on a hill too:
Man, those are 17's? Look bigger than that.
I'd really like to go bigger than stock sizes i.e. at LEAST 215's if not 225 if possible. So I assume you would say go et42?
if your car is lowered (or will be) then yeah, probably 42..stock is 48 and only 7" wide so they'll still be out almost an extra half-inch...mine are out 3/4" more than stock or something like that
I LOVED that wheel. A nod to the prodrive rally cars, super BBK freindly. It went the way of the dodo bird after SSR's re-structuring, with the Comp machiened lip, and GT2 and GT3's.
