R53 18x8 clearance question
well i just got these wheels and i want to know if i need to run spacers and if they will even work!
rim size is 18x8 45 offset, and im going to run 215/35/18 so they will have a little stretch to them
the rear:
![](http://img13.imageshack.us/img13/1479/dsc0034ctb.jpg)
there is a finger gap there
![](http://img13.imageshack.us/img13/6466/dsc0035rsd.jpg)
also a finger gap there
![](http://img13.imageshack.us/img13/426/dsc0039hlz.jpg)
the front:
![](http://img13.imageshack.us/img13/7161/dsc0036uij.jpg)
every small gap, maybe like 3mm
![](http://img13.imageshack.us/img13/8056/dsc0037dsi.jpg)
![](http://img13.imageshack.us/img13/6825/dsc0038jyv.jpg)
so with spacers will they work or stick to far out?
thanks
Fred-
the rear:
the front:
thanks
Fred-
You might need a 5mm spacer in the front just like I have. You also are going to need to trim a lot of your plastic trim off if you are lowered. I am running 215/45/17 with an 48offset and I could not bolt my front wheel on due to it hitting my coilovers. A 5mm up front fixed the problem and the rears are fine. I scraped my wheels on all 4 corners until I trimmed some plastic off and still do sometimes.
Shoudl just clear no problem
andrewjg1994
01-29-2021 07:45 PM
R50/53 R53 Chrono Pack - gauge?
missinmyjeep
08-22-2015 07:13 PM
