If I don't use the valve stem, and instead use the barrel mounting point, do you carry a TPMS sensor that would work? I am planning on getting the Yokohama's off of tirerack to go with the wheels so if I could get TPMS from you it owuld be much easier.
All my stock compatible TPMS monitors are held in place with the valvestem. I dont have a system that will mount without using the valve stems, that will be Mini TPMS compatible.
