Valve stem leaking at the base.
Old 07-09-2009 | 10:44 PM
STLMINI's Avatar
STLMINI
Wife comes home and says the tire is low. I check it out and it's completely flat. I go to fill it up and after I do I realize that when I move the valve stem in all but one direction I get psssssst.
Is this something I can fix or do I need to take the tire to a shop.
FYI, this is a standard valve stem... aka no TPMS.
Old 07-09-2009 | 11:28 PM
minimarks's Avatar
minimarks
You need to take it to the shop and get a new valve stem.
Old 07-10-2009 | 12:46 AM
darmog's Avatar
darmog
Could just be the valve core has come loose a bit. You can buy a valve stem core tool to tighten it if it is indeed loose from your local auto store.
Old 01-25-2011 | 07:42 PM
gawannamini's Avatar
gawannamini
I had an ugly surprise last week - flat tire on interstate.
I have 17" webspoke wheels with the standard tire pressure monitors on my 2009 MCS Convertible. These metal inflation stems have a nut on the outside that holds and seals the tire stem to the wheel. The nut had come loose and there was nothing wrong with the tire. Once I had the correct socket it took almost 3 full turns to tighten the nut !!! This car has only 15,000 miles on it. The other three stem nuts were fine.
patsum
26
05-29-2021 07:29 PM
sempaipaul
10-26-2015 06:56 PM
ShadyCoop
09-08-2015 05:50 PM
joshuatrost
09-05-2015 03:58 PM
09-02-2015 10:05 AM
Quick Reply: Valve stem leaking at the base.
