Another r56 wheel question
hello all...i have a 2007 r56 s and i wanna get some new wheels. but it seems like not all wheel accept the 14mm lugs, TPMS sensors, whel hub etc. so other than factory MCS wheels is there a wheel manufacturer that will more or less bolt right on to the mini? im lookin at 17x7 and 215 45 17 wheels/tires but it seems like im going to need to spend several hundred extra before i can even mount any wheels to the care.
thank you
thank you
thank you
thank you
If you don't like the s-winders you can check tirerack.com and they will show you which wheels will fit on your car and you can even see what they look like with them on the car.
Good luck with your search.
Hey, I'd suggest you call Alex@Tirerack He works for Tirerack.....posts here a lot and has helped a bunch of people here on NAM with wheels and tires. Seems like a great guy. I think he is also a moderator. I looked up his contact info for you;
Alex Mouroulis
Performace Consultant
The TireRack
877 522 8473 xt 294
moderation on 3si.org &
northamericanmotoring.com
email is best - alex@tirerack.com
Alex Mouroulis
The TireRack
877 522 8473 xt 294
07-16-2020 12:54 PM
thebordella
08-31-2015 01:37 PM
Mini'mon
08-16-2015 04:15 PM
ki7hy
08-12-2015 07:07 PM
