removing "Pound On" Wheel Weights
Hello! I apologize if this has been asked before, but I couldn't find the answer I was looking for using the search engine. I should also warn you that I know very little about wheels and wheel weights.
I recently acquired a 2009 Mini Cooper S with 16" white powder coated wheels. I noticed that there are "pound on" wheel weights on the outside of the wheels instead of "sticky" wheel weights on the inside of each wheel. If I wanted to remove the pound on weights and replace them with sticky ones, how could I do this without damaging the powder coating on my wheels?
Thanks!
Thanks!
Thanks for the replies!
I wasn't planning on doing anything myself, since I'm not a professional, by any means. I was just wondering if I could take the car anywhere to have the "pound on" weights removed and then replaced with "sticky weights." It sounds like the powder coating on the wheels has already been damaged, so I guess I won't worry about it, now.
*sigh* Oh well, they don't look too bad. I'm sure I'll survive! Thanks again!
All the unmounted in this photo had damage from the factory installed weights. Four of the unmounted I had replaced tires and the weight damage from the new was worse than factory ones. I'm sure when I replace tires on the mounted, they too will have damage.
Obviously, MINI came with many different wheels so I can only speak to the ones I have here. But there is likely damage under the weights.
Don't get me wrong, if they bother you get them replaced with stickies. I'm just saying you might be disappointed when they leave marks behind.
One little detail about 'pound-on' wheel weights (from experience) - and seeing as you're in PA - by nature of the mnfr'g of wheel weights, sharp edges exist on the clips of the weight - when installed, they cut into the coating on the inside of the rims - take a little salt, add some moisture, on aluminum rims, with the steel clip, and voila! you've got a middle school science project: corrosion - it will build between the rim and the coating (paint/powdercoat/chrome - doesn't matter), loosening the coating and creating a bead leak, that requires grinding to remove so the tire can seal properly - anytime now that I get a car w/ pound-ons, I have the bead broken and bead sealer installed, along w/ the stick-ons...
ltjpunk7
09-06-2015 07:32 AM
minipopkart
08-13-2015 05:22 AM
