Tire choice on a 17x7.5 +40 offset wheel & lowered on BC coils
long story short, i smoked my Goodyear Eagle F1 GS-D3's in 215/40R17 during our trackday a few weeks ago and looking to replace them with the Goodyear Eagle F1 Asymmetric. here are the options for the sizes:
215/40R17 (no stock, dealer will need to order from germany)
215/45R17 (in stock, taller than OEM diameter)
225/40R17 (in stock. smaller than OEM diameter)
wheels are Volk Racing TE37/SE37 in 17x7.5 4x100 +40. current suspension setup is BC coilovers (front on full drop, rear probably at middle) with HSport rear lower control arms
i'm undecided between the 3 choices but each have their own pros and cons (wider means more traction, taller means more MPG on the highway etc). i'd get the 215/40R17 in a heartbeat but that will take at least 2-3 weeks to get here. with the 215/45R17 the Mini might look too tall. with the 225/40R17 it might rub the dampers. HELP!
I am running 215/45/17 on and it looks great. I had tried a few good track/street tires and for the price and performance, none were better then the Sumitomo htrzIII. I got them for $86 a piece from my local tire store. Great tire and it looks great. I am also lowered with BC's on the lowest drop in the front and half in rear.
$143 each 22 lbs If you have lowered your MINI and the wheel gap is small then 215/45-17 will likely rub and you will need to raise your ride height at least 1/2 ".
I only see them in 215/45-17, what source do you have?
Another option would be
Bridgestone Potenza RE-11 (extreme summer tire) 180 treadwear
205/45-17 $167 each 23 lbs fits your rim and not too tall, should work fine
215/45-17 $175 each 25 lbs
If you want best performance and good for track use then-
RE-11 in 205/45-17 and get some front adjustable camber plates so that you can make use of your tires and not wear them out fast. Dial in -2.4 degrees front camber.
07-16-2020 12:54 PM
SosoMINI
11-22-2015 03:17 PM
Mini'mon
08-16-2015 04:15 PM
Rennfahrer555
08-13-2015 09:07 AM
ki7hy
08-12-2015 07:07 PM
